To create a key performance indicator (KPI) for training per department in a healthcare organization, you will need to collect data on the amount of training that is provided to employees in each department. This data can be collected through the organization's training records or by reviewing individual employee training records.
Once you have collected this data, you can calculate the training per department by taking the sum of the training hours provided to employees in each department and dividing it by the total number of employees in that department.
Here's the formula for calculating training per department:
Training per Department = (Sum of training hours provided to employees in each department / Total number of employees in that department)
It's important to note that the specific time period you choose to measure the training per department will depend on the needs and goals of your healthcare organization. You may choose to measure this metric over a day, week, month, or any other time period that is relevant to your organization.
By tracking and analyzing the training per department over time, you can gain a better understanding of the training provided to employees in each department and identify areas for improvement. This can help to ensure that employees have the necessary skills and knowledge to effectively carry out their job duties and support the overall goals of the organization. It's important to consider other factors that may impact the training provided to employees, such as the availability of training resources and the specific needs of each department, in order to get a comprehensive understanding of the organization's training efforts.
